B585Ford, the A1000 or fuel lab. Will my harness plug in to it? The frame rail fuel filter setup 7s called a fuel bowl? Why? What are you talking about cleaning up the engine bay? Do you remove the filter assy from the engine.
Marty's kit should provide everything you need. If you are interested in the Fuel Lab, you should send a PM to Morgan (Sledpull) or Side Action (in a few weeks - they haven't release their version yet). Since Fuel Lab doesn't offer an official kit for the 6.4 at this time, I suspect Morgan provides a connector, but IDK for sure. BTW here is a suggestion. When you do a LP system, I would suggest plumming a gauge into it. I just did that on mine and it already came in handy. I had to replace my HPFP because it was taking a ch#t at only 60k miles and I am religious about maintenance. I am sure bad fuel was the biggest factor, but I wondered if I had upgraded my LP system before, would it have prevented this. Anyways, just had Marty's kit installed along with a "new" reman HPFP. Long story short, when they dropped the cab, my truck wouldn't stay running. After rechecks and making sure there was no air in the line, that gauge provided a quick tool to confirm the LP wasn't the problem. After discussing the results with Ford, Ford agreed the new HPFP was bad and is sending a replacement. I will feel more comfortable when driving knowing exactly what fuel pressure my HPFP is receiving.
