Swamps uses there own controller to make the 6.4 stuff run on the 7.3 computers right?
If thats the case, couldn't you use the controller to swap a 6.4 in to an obs or a 7.3 superduty, and then get a pcs to control the transmission. That would be the "easy" way to swap a commonrail motor into an older Ford.
