60' times before and after traction bars.
Kind
This has me wanting cal tracs again. I've been talked out of them soo many times but they seem to work.
Caltrac's work as good or better then any other leaf sprung traction aid. The only people that don't like them are the ones either supporting other brands or just didn't take the time to set them up. Other then that they can be noisy on the street and don't do anything to help the axle when unloaded.
For 4wd's a axle wrap bar will work well and good enough for most scenarios... But you'd never catch me running a strait bar on a 2wd.
bigrpowr
<How I Fly
Administrator
Sounds good, guess I'll start at 1800rpm like has been said and go from there.
What should I drop my tire pressures to? It's on Michelin LTX AT2 275/65r20 and stock 20's till next week
Sent from a Cummins plant, driving a Powerstroke, with a TDI on the side!
30 front 25 rear. you want LESS air in the rear due to no weight.
Kind
Yet on my truck they make very little noise. I had mine set up so they were touching or up to half a turn tighter.
Dzchey21
wyoming
30/25 has always worked well as a starting point, basically want the sidewall to start flexing
I did run into a situation and didnt know it untill i was testing my bar/shock combo that you can actually transfer enough weight to the rear to overload that tire pressure. Only real way is to do a 4wd burnout and check your contact pattern, i was severly overloaded on the edges of the tire and almost nothing in the center, 5 psi more air in the rear fixed it. Were comparing apples to oranges weight distribution and power wise but its something to consider
any fixed bar seems to work. pick your budget.
OUO's sure are sweet but they come at a price.
i run PMF and they do me well...
