7.3 Blocks. Anyone heard of this???
04stroker
Sarasota-Bradenton, Florida
I had someone tell me that a 2003 block should always be used in a high horsepower 7.3 build because because "it has more thickness and was made with more supports inside around the cylinder for strength" than the 94.5-97 blocks.
I have never heard of this honestly and just wasn't sure as I am not a huge 7.3 guy and don't keep up with them a lot. Anyone know one way or the other for sure?
ToMang07
Mainah!
I think it was just a little more meat on the 99-on blocks versus the OBS blocks.
JD3020
Farmersville/Dayton, Oh
I'll try to dig out my "Powerstroke Bible", has pics showing the difference from the early 7.3's, to the later with the stronger blocks. Pretty sure the changeover was 96/97
superpsd
Missouri
For starters the early block does not have the Webs across the lifter valley. Think it was like in late 96 when they made the changes?
1005dp_01%2Bdiesel_power%2B2002_ford_f250_power_stroke_diesel_rebuild%2Blong_block.jpg
Powerstroker7.3
waxhaw NC
I'm pretty sure it is just the webbing thing that was changed but the blocks should all be good from 97 and up. I used a 97 block when I built my motor
Austin, Tx
I remember reading in a book I got from a Ford mechanic that the valley was slightly thicker and the webbing in the lifter area, but don't remember anything about the cylinders. I also remember the cranks and pistons being different too.
