does it stall out or cut out? stall out means it kills the truck, or is it more of a stumble/hiccup and stays running. does it do it while cruising at idle, a set speed, wot, or just partial throttle?
Truck is cutting out under throttle, idles fine, just seems to do it while driving and yes it does start back on its own almost like it just comes back to life
Cam sensor. I had the same happen in my father's obs. Full tilt boogy the.bamn nothing for a second, then rips right back into running again
sent while looking at a hole in my block
I just went through the same deal. Cutting out and running like crap in certain rpm ranges. Sometimes when throttling it would shut off, WTS came on and it would start up and keep rolling. I put a CPS from ford in it and it quit. Before the one from ford I put 6 from advance and it changed nothing every time. It didn't have any symptoms of a bad CPS and everyone I talked to thought I was crazy when I said I thought it was the CPS. Finally I put one in from ford and it fixed it.
