afe big boost?
Eastern Shore Of Maryland
Well I've been thinking of doing a custom intake using the big boost filter from afe. Its basically a 6637 but rated at 850 cfm. My question is will this be enough air flow? I'm pretty sure it will being s&b only rates at 563? Any info helps.
weazel
Elkview WV
As long as the intake you build is not restrictive it should work. I built my intake it does the trick. I used 4" piping and an AFE filter. I don't recall the part number but everything works.
JAP
Diamondhead,MS
Yes, it will flow plenty. Let me know if you want one because I'm still running a special.
