Air deflector thingy..
6speedsd
Olive Branch, MS
Y'all know what I'm talking about...whatever the technical name is. That obnoxious shroud piece between the fan and radiator that's in the way of damn near everything. I know it was designed and engineered for a particular reason, but is that reason beneficial enough to keep the thing on the truck? I have the truck apart now, with all that off to replace a water pump, among other things. What will it hurt to toss is to the side of the garage and make life a little easier under the hood, considering how much time us 6.0 owners spend there. I mean if it really is beneficial to have it on the truck, I'll put it back on. But if people leave it off all the time with no negative effects, then sign me up as part of the crowd.
Radio
Gillette, WY
I was wondering the same thing. I'm due for a new belt so I'll be pulling that piece off again.
acf6
Manchester, CT
I didnt even know they had one til I saw a post a few weeks ago lol...mine hasnt had one since I bought it last feb and I haven't seen any problems...
GFDtech
This part ? It's the fan stator
Cutting-Edge Diesel
Newkirk, OK
I take them off of trucks I put compounds on and it doesnt cause any problems that I know of.
Edit: only the part that bolts to the motor dont take off the part that bolts to the radiator
6speedsd
Olive Branch, MS
Yea the stator. Knew it had a technical name, just kept drawing blanks last night.
No the shroud against the radiator will stay. What about the 2 studs that bolt the bottom of the stator to the motor? I noticed they had quite a bit of loctite on them...they don't go into a water passage or anything do they? Didn't want to leave those off if they were plugging a port or something along those lines.
GFDtech
No just the block ! How you going to support the fan wiring is your next question.
GFDtech
Never done it but just got the cab down on the one I'm working on and that should work.
