AKF250 Alaska Build - (650-700HP BUILD)
akf250
Recommended Tuners
You should get some good tuning instead of that PPEI chit
What is your recommended tuner for the EZLYNK instead of PPEI?
Would I mention anything specific or just mention my mods and go from there?
Can you have two "Technicians" on a EZLYNK at once?
Well seeing as PPEI now no longer supports race tuning, you are forced to change. And yes, you can have multiple technicians on one device. I would give No Limit a holler and see what they have to offer. Mention your mod list.
akf250
NEW BADGES
Hey Everyone!
Got some photos of my new badges I got built by Billet Badges.
Been waiting for while, around 6 months from design to arrival.
I drew this design out about 8 years ago and it came out better than I could have ever imagined.
akf250
Badges
Those are sweet! What did something like that cost?
Sent from my SM-G960U1 using Tapatalk
$835 for the custom side badges and custom rear badge
Doing less colors is cheaper I believe
akf250
Hello Again Army,
Been having fun with the truck. Its been running great on the highway and hauling my truck bed camper with a boat behind it no problem. Temps are great, sounds good, pulls great on hills, etc.
But unloaded, I have been having a issue with Abrupt Wide Open Throttle pulls since I completed the build.
If I ease into a Wide Open Throttle pull I have 0 issues and the truck pulls hard.
If I do a abrupt boosted launch or lets say I have it on the dyno and I am trying to get a number, it falls on its face and runs really rough at 3/4 throttle and on. The motor shakes until I let off the throttle and then everything cleans right back up and I have no problem.
What could be causing the issue?
A mis-performing injector or HPFP? Reset Adaptive Tables?
Trucks got a FASS 165, a brand new stock HPFP, Fuel Bowl ******, and all the injectors were sent to Oregon Injection to get bench tested (stock tips/stock fuel)
I ******d the Fuel Cooler but this issue occurs even when fuel is below 70 degrees.
I am getting no codes at all and no irregularities in the injector contribution test when revving the engine ( I have not done Wide Open Throttle passes while analyzing a injector contribution test yet)
Thoughts?
sound like dropping rail pressure. does it do this on all tunes or only on the hots ones.
akf250
Tuning
Non-Hot Tunes? What are those for? Haha just kidding
No, I haven't tried any lower tunes yet, would be a good test. My goal is to get it running good on the hot tunes of course. Guess I'm just confused as to why I am having these issues with the exact same fuel system and the same level tune that I had before the build. All I did was add a lot more air and free'd up air flow.
Could it be?
FASS pump adjustments?
Fuel Bowl Regulated Return Adjustments?
Don't see any external fuel leaks and if I had some form of fuel leak under pressure I am sure I would have noticed fuel in my oil by now.
akf250
Well I decided to check out the old forum again.
Happy to report the truck is still running great after 40,000 miles on the build
I don't daily drive it so it only gets miles on camping trips with the truck bed camper and pulling trailers
Finally re-did my CCV and solved my issues with exhaust haze and oil burn
There was too much crankcase pressure due to too small of gauge CCV lines
Had a leaking coolant stock hose so replaced all those with the Mishimoto Silicone hose kit
Had a constant velocity joint go out
Besides that I have been mostly redoing interior creature comforts. Dynomatted all the door panels and installed a new stereo system all around. Re-worked my wiper cowl, painted my taillights, and started to redo the lights on the front bumper.
Guess I never really reached my goal of 650-700 HP like this forum was titled, but I never really tried that hard to reach it after it was running. It does everything I need it to do and has been reliable.
I believe with a little tuning I could easily reach my goals
Trucks never going to be sold, so one day it'll reach those numbers if not more
