Alradco 6.4 radiator review
weekendwarriorfsw32
Central California
Well I thought I would make a new post after having it installed a little under 2 weeks. The fit and finish of this radiator is very nice and every mounting tab and bolt hole are dead on where they need to be. I was not expecting to see any drop in temps but right off the bat I noticed a 4 degree drop on coolant from my normal 200 temp rolling down the highway to 196 now rolling down the highway. I saw an even greater difference in temps when I was towing into the Sierra's up to Reno from the San Francisco area, I start at sea level and climb to about 7,000 ft. On this trip I had about a 14,000 lb trailer and at the summit of donor pass I am normally about 225-230 on coolant temp. On this trip when I reached the summit I was only at 210, thats a 15-20 degree drop from what I normally was and I was shocked that is was that much of a change. Here are some pictures of it being installed
Here was the 14k load that I had going up to Reno
Over all I am extremely happy with the new radiator and so happy to get rid of the crappy stock plastic end tanks that are aways leaking which leaves me to have to worry about one less thing leaking and leaving me stranded while on the road.
Fordtrucks
Hmm, cheaper than mishimoto then... My stock one has never given me trouble tho..
AllGo'N'Show
West Canada
Fordtrucks, It likely will one day, how many miles do you have on yours currently?
Great review Nick, really positive results as well thanks for sharing.
B585Ford
WV
Thanks for the review. This is the route I was planning on going when my stocker started leaking. This is making me that much more certain this is the route I will go!!!!
B585Ford
WV
I can send you my leaking one if you want an excuse to get one!LOL
Thanks, but if will just send a pic of yours leakin (so that you can't see the truck's color) I will show the wife and tell her that Rykan found this and I need to get one now.
alradco
When we started on this radiator I had no idea what we were in store for, definitely one of the most challenging projects we've taken on. All I had in mind was to make a drop in style replacement aluminum radiator that eliminated the leaks that we see more and more of these days with the plastic factory radiators. To see your results Nick takes this project to another level. Thank you for your input and support along the way. It hasn't been an easy road but to see results like is absolutely awesome.
With that said. The radiators are on pre-sale special until the end of this month for $739. After that the standard price is changing to $939. You can pre-order at www.alradco.com, the deposit is $100. It's family dinner night and we're celebrating my mother in laws birthday tonight. I'll post more info on the radiator tomorrow. Thank you.
Peter
Fordtrucks
What gives on them? The tank starts leaking?? I mean every part on these trucks will fail at some point.. I don't usually replace perfectly good parts..
powerstroked08
Pennsylvania
The end tanks are crimped on and will start to leak where they meet to the core. I have seen a few of these now. One is on my truck now. Mine is leaking on the top driverside. My buddies is leaking on the bottom driverside.
Erikclaw
Central CA
Makes me wonder what the one I am getting will do in the way of temps. My stock tank lasted about 50k after it went then everything went to hell. lol
