Baking headlights.
Pmac21
Holly Springs, MS
stealth-automotive.com is where I got mine. Lifetime warranty. I had one go out and within a week I had a new set. :thumbup:
campbellflage
Hudson, FL
Just started doing a set today, man was it a ^&*&H to get free, took forever to get it to come loose. But finally got one it apart and cleaned up, gonna finish up the other one tomorrow.
08BIGRIG
WI
If you use night shade paint it will depend on how many coats you do. I did 3 coats and they are pretty dark but you can still see the light.
102297[/ATTACH]"]
This truck looks absolutly beautiful man!!! What rims are on the truck and are those 35x12.5x20 tires? Really clean
bigastrk
Cartersville, GA
Whatever you do, DON'T paint the headlight bucket that the bulb reflects off of. Ask me how I know. The set I had received a burn from bad hid's. They look cool but don't work worth a crap!
Poglife
Georgia
Turn signal bulbs that don't look orange until you turn them on.
what did you use for the white on the reflector?
did yall sand the chrome off and then prime it with etch primer or adhesion promoter before paint?
Pmac21
Holly Springs, MS
The white is dupli color color match spray paint Oxford White. I cleaned the chrome with alcohol and then sprayed adhesion promoter and then the white.
08forddr
maryland
Well, I just got around to take mine apart and painted them. I am putting them back together this weekend. I put LED strip in white at the top the reflector and painted with gloss black. I also put the same bolts that are on my grill on the reflector. I will post pics this weekend.
What did you guys use to seal them back up?
08forddr
maryland
My finished lights. I did a led strip above the bolts in the reflector that i nightshaded so you could 'nt see it in the daylight.
08forddr
maryland
Here you go....
Sent from my SCH-I605 using Tapatalk 4
