mcdaniel1991
Like the title says, where should I order my gauges from? I'm looking for coolant pressure, egt 0-2000, fuel psi 100, and volts
Sent from my GT-I9305 using Tapatalk
Hummm... Coolant pressure... Not a gauge I ever thought to run...
MICHAEL, I need a new gauge buddy! LOL
What kind of pressure does a 6.0 run for coolant? Does it simply match the boost pressure... LOL I AM KIDDING! LOL
LOL well I was thinking it would be a good way to keep an eye on the head gaskets, since i already have a factory boost gauge. Should i swap the coolant psi for the boost 0-60 R17233?
I'm actually curious what the coolant pressure would run driving down the road... Might have to get one for my truck as a test gauge.
Well from what i understand it still shouldn't go over 16psi? so my idea was if i have the gauge then i would be able to tell if my HG are starting to go.
Are these necessary?....ISSPRO Pressure Gauge Snubber, 1/8NPT male inlet x 1/8NPT female outlet
DESCRIPTION:
This device was designed to reduce pulsating in pressure gauges, 1/8NPT male inlet, 1/8NPT female outlet, rated to 3000PSI. Comes with 3 different sized pistons:
#2 Piston for Diesel Fuel Pressure
#3 Piston for Air Pressure
#02 Piston for Oil Pressure
