I Like them tunes.smooth on the tranny, upshifts when u need it, no smoke. going to drive it a few more miles (dont drive it every day) doesnt seem to pull as hard than DI tunes
Matts tunes your going to use the whole pedal. Other peoples tunes are maxed out before you go full throttle, hence acting like other peoples tunes have more balls
Yeah havent got into it real hard yet. Guess ill give it a try tomarrow
Best way to set up the 38r IMO is to remove the wastegate hose, plug it, and then set the wastegate rod so it swings about 45 degrees when you apply air pressure to the pod. This will regulate you to about 34-35lbs of boost in my experience. If you have the turbo off the truck, I would go ahead and drill a hole of the same size as the wastegate hole through the divider by going through that same hole. This will help equalize drive pressure when the wastegate opens and does very little to hurt spoolup.
Matt would you care to elaborate a little bit more on how to properly set up the waste gate I usually get only bout 30 maybe 32 pound of boost. I've never messed with the WG since the turbo has been installed just bought the turbo and put it on as is. I'm sure it could use so e adjustment
Mine has the red line off and plugged as well. I regularly see 40 psi.
