boosts numbers matts tunes
mudwizer
What kind of boost numbers should i be seeing with 238/100 38r and matts tunes in race mode
farm boy
Rosharon, TX
Mine was a little low at one point also. I replaced my valley boots with some from Riff Raff, and added his plenum inserts and t bolts. Fixed me right up.
OSCS
Houston, TX
I see about 41-43 with my 366. How do you like the tunes so far? I wasn't a fan at first but the More I drive my truck the more I've learned to appreciate them. They do take some getting used to after running David's.
mudwizer
I just about got the gate locked down.I have a waste gate controler from Dieselsite
mudwizer
I Like them tunes.smooth on the tranny, upshifts when u need it, no smoke. going to drive it a few more miles (dont drive it every day) doesnt seem to pull as hard than DI tunes
OSCS
Houston, TX
I agree but I finally got around to boost launching it this weekend and it still has plenty nuts.. I'm throwing it on the rollers Saturday to compare it to David's corrected 542rwhp. I'm confident it will make 520-540
SDstroker
SE, SD
Matts tunes your going to use the whole pedal. Other peoples tunes are maxed out before you go full throttle, hence acting like other peoples tunes have more balls
OSCS
Houston, TX
Very true, I didn't realize how much power his tunes had until I REALLY got into it.
Gearhead
Best way to set up the 38r IMO is to remove the wastegate hose, plug it, and then set the wastegate rod so it swings about 45 degrees when you apply air pressure to the pod. This will regulate you to about 34-35lbs of boost in my experience. If you have the turbo off the truck, I would go ahead and drill a hole of the same size as the wastegate hole through the divider by going through that same hole. This will help equalize drive pressure when the wastegate opens and does very little to hurt spoolup.
Tncoalroller88
Piney Flats, Tennessee
Matt would you care to elaborate a little bit more on how to properly set up the waste gate I usually get only bout 30 maybe 32 pound of boost. I've never messed with the WG since the turbo has been installed just bought the turbo and put it on as is. I'm sure it could use so e adjustment
Gearhead
just shorten the rod on the wastegate until you get 45 degrees or so of travel when the wastegate fully opens.
