GROSSpolluter
Due to a oil leak. So im doing head studs and wanted to do batmowheels. My question is are they available yet and can you drive them on stock tune with dpf for smog checks?
I think it showed a 30-35 HP increase on a stock truck (tuner, intake, exhaust, EGR delete) using IDP's X-race file. That's not bad if you ask me.
id rather just swap the atmo for the tow power atmo, less work for more gain.
Another question. Is it worth doing egr block off plates?
for you it is. the new cali smog law makes it so there is no way around the egr delete.
You can swap the wheels without pulling the turbos if your curious. I've tried it too.
You can do the atmo wheel only. It was only a couple hour task from start to finish.
That's the one in the front that the intake hose clamps to right?
Im just trying to figure out what to do with cab off....that's not crazy expensive.
Any numbers on swaping both wheels ?
