can stock rods be reused?
94forddiesel
Ashaway, RI
im getting pistons and since there a fractured rod ive heard i need to also buy new rods but i have also heard you do not does anyone have info on this? thanks
webb06
Seneca, MO
I reused mine. Twice. No problems. I did see a video from a ford master tech saying they needed replaced after each use just recently though.
webb06
Seneca, MO
Most new ford short blocks have reman rods in them.
Search YouTube
6.4 damage piston pt2
He shows new rods and says one time use.
Not saying you're wrong because I've never bought a short block.
Just giving a little info
blk350on20s
I reused one rod when I cracked a piston. That was at 47000 miles. I'm at 120k now. And its seen some good power
94forddiesel
Ashaway, RI
ok guys sounds good as long is there not messed up i will just get new bearings and reuse them plus i got 2 engines so i have 16 to choose from lol
kyle43335
check your twist, and center to center measurements. is they spec out? use them.
when i built my 6.4 in my 450 i bought new. they are not expensive for stockers
