Compression test procedure
psdguy95
Effingham, IL
I would like to do a compression test on my truck but i have some questions.
1. Should i remove all gp's?
2. Do i need a special type of tester or will any type work?
3. How many cranks of the motor should i do?
4. What specs should i be within?
5. How high should the numbers on my compression gauge read?
onebad7.3
MI
1. Yes
2. The thread is M10x1.0
3. I crank it 5-6 times to get a good reading.
4. You should be around the 400 psi mark. If your anywhere from 365ish and above you'll be ok. As long as the lowest reading is within 75% of the highest reading.
5. As long as the gauge goes to 500 you'll be fine.
When you pull the glow plugs out, don't let oil run into the cylinder. It will make your numbers a tad higher than what they are. I'd used a little compressed air to blow the oil away from the glow plug.
I have another truck with jumper cables on the truck i'm testing, so the batteries won't get run down. Cranking fast at first and then slower and slower can give you lower readings.
TrailerHauler
Michigan
1. Yes
Pretty spot on, that's how I've done all mine.
MossBack
UTAH
75% seems a Tad high for differential pressure. I thought it was 15-25% ?
Sent from my PC36100 using Tapatalk
psdguy95
Effingham, IL
Well i just found out all 3 of my compression gauges only go up to 300. :doh: Ill see if i can find one at school tomorrow.
onebad7.3
MI
Yeah I screwed my percent up:cursing:
Just post the numbers and we will tell you if its ok
MossBack
UTAH
Ur cool bro I was curious as I want to test mine too. I just about dropped 200 on the snap on diesel compression tester. It is a combo kit for like 10 different Diesel engines. But ill just go the harbor frieght route I guess.
psdguy95
Effingham, IL
How much is the harbor frieght one?
MossBack
UTAH
40-50 the problem is making the connector to thread into the gp hole. U have to be able to wiggle around vavle springs. Snap on kit has a flexible hose, while some people Fab there own. All in all I bet the snappy kit is worth it for safety and reliability
Bushwakd
Northern,Virginia
True true. Do i have to disable the injectors when i do this too? Or can they stay plugged in?
When you disconnect the main wiring harness to the under valve cover harness does that not interrupt any power signal going to any injector. I believe it does. But any ways since the glow plugs are unplugged and removed just unplug the injectors and remove the UVCH and gasket and get it out of the way.
MossBack
UTAH
Adapter
My snap on guy has a different brand that is a complete kit with one of these and a few others for most diesel engines. IIRC it was like 250 ill find out thursday and if it is that close in price to HF ill buy it.
psdguy95
Effingham, IL
Sweet. Let let me know on the price. Whats the part number on that? I can give it to my teacher if i want to order one.
MossBack
UTAH
EEPV314A FORD/NAVISTAR 7.3L POWERSTROKE Yes $79.99 $79.99
EEPD500 DIESEL COMPRESSION GAUGE Yes $170.99 $170.99
Subtotal: $250.98
MossBack
UTAH
Star product was what he had and it was 213.15.
