Coolant filter ?
fine69
Cranberry Twp,PA
I have a Dieselsite filter kit on mine, you would be surprised at the amount of casting sand it catches in the first 2-3 filters after you install it!
03international
Centreville
I built my own with a coolant filter housing and I built a mount with a plasma cutter with a piece of aluminum. just installed it. going to change it in about 300 miles
fnlyfree
Alabama
I have a dieselsite kit too. Went on pretty easy. And as fine69 said, the amount of sand that it catches is pretty amazing. Really don't want that going through the water pump.
Pizza pig
MD
Dont want casting sands clogging your oil cooler either...
Hellen Keller sent this?
gman1
Michigan
The coolant filter is cheap insurance and easy to install. I run the Dieselsite setup.
