04hdfatboy
- Joined
- Aug 16, 2012
- Messages
- 118
- Reaction score
- 0
Darn. Now I'm afraid to do studs lol
They seem to crack after the second or third time being torqued. The block we cracked had the original A1studs in for 35k miles torqued at 190 ft lbs. Motor was pulled for new pistons. Same studs were reused but new spec called for 210ft lbs. Motor went 50 miles and coolant was leaking out of threads on one stud. Job was redone this time sealing threads with liquid teflon. Went approximately another 50 miles before crack spread to the lifter galley, flooding engine in coolant. The crack runs horizontally front to back 4 threads from the bottom of the hole. Almost like the block pulled apart with the torque. The stud with the issue was on the right hand side second stud from the back, top row. Right where the casting is the thinnest. Truck now has a new block with studs torqued back at 190 and so far isnt leaking.
So from what im gathering most of the issues have been on the second, third ect. retorque, or on the trucks that have added some torque to the final pull on the studs. Is this a fair assessment?
How much are people filling these blocks? And are these trucks able to be daily driven with the blocks filled?
Its just weird how these things happen. I just want the same block that Nick has(extreme3807) Hell his is handling 1300+horse on all stock internals! But some trucks are popping at 550-600...... :wtf:
He's running all stock bottom I believe. At that power I hope it holds, but I believe it will not last to long.
I think I will solve my cracked block issue before it happens. Just get a 6.7 with a warranty.....
