Crankshaft Spacer
groove
Okanagan BC
Well, just got all my stuff back from the machine shop and noticed that they pulled the spacer off the back of the crank:doh:.....how bad is this going to end up?
Can I install it and put a dial gauge on to check run out or....
Let me know from those who have been here.
groove
Okanagan BC
thank you, that's what I was hoping.
Now, I have to position the dowel (on adapter) on the crank as that determines the cam timing if I recall.
Any ideas on how to accomplish this?
Cutting-Edge Diesel
Newkirk, OK
The hole in the adapter is 180* off from the keyway on the crank gear.
HOOV3R
Central PA
Bolts are also TTY, and must be replaced. That is not considered a removable part, so they will not be listed. They are the same as the damper bolts.
Cutting-Edge Diesel
Newkirk, OK
Why? So they can just bolt it back on? There arnt any instructions on how to put it on I would feel safer doing it my self. I just went threw having to pull the trans on a truck we put a used short block in and the adapter was put on wrong.
Just get 2 packs of balancer bolts and blue lock tight and bolt it on. Easy fix. Check the run out if your not sure.
04stroker
Sarasota-Bradenton, Florida
Exactly ^^^
groove
Okanagan BC
Machine shop has offered to mount it, regardless I will be checking run out when I bed the crank prior to installing the pistons.
