elite 72mm atmo
6.4psd916
Roseville , CA
Installing one right now in my mini garage by myself. Wish me luck.
08BIGRIG
WI
You will love the 72 buddy!!! Very fun street turbo forsure. Good luck
BFT
southern cali
You'd probably have to open up the casing to see if you could take it apart and find a new piece to have it pressed it. I don't know if ford just sells that piece alone. If not then all you'd need is the actuator, all it is is 3 10mm
White_monster
The great white north
If that broke off the actuator you need a new actuator. If its off the turbo side the. You'll need to find a turbo to rob parts from since the parts are sold from ford. Best of luck.
6.4psd916
Roseville , CA
Thanks guys, I might just have one made at work Monday. These up pipe bolts suck, and my turbos were off less than 10k ago.
Diesel23
NWI
UGH !! Good Luck Man , always something !!! Im sure it will be all SMILES after
INFAMOUS
Denver Colorado
IIRC, You can not buy that separate. You will have to rob one from another turbo or make one.
Sent from my HTC6435LVW using Tapatalk 2
Wayne
Twin Falls, Idaho
We might be able to sell you one as we have new ones custom made. I don't know the price, or availability, but we do have them most of the time. Worst case scenario, send it in as a core on a new billet 59 VGT. :naughty: They get damaged in shipping to us frequently as people are too lazy to box them up properly.
6.4psd916
Roseville , CA
Thanks Wayne, but I'm going to have one made one I get the old one out, no cash for the vgt and is my Dd so I need it running.
BFT
southern cali
Are you using an extension long enough to clear the uppipes. I know you can do it man all you have to do is crack it loose and it's butter
