campbellflage
Truck died last night on me, got a p1316 code and I was thinking maybe ucvh went bad, but this am I replaced it and the gasket just to be sure, went to fire it up and still nothing, codes are p0603, p0475, p1316,p0541
did you find any specific damage in the harness plug? How did all the plugs on that bank ohm out? Did you buzz them?
Funny that there is another thread for exact same thing..Our old junk is baffling sometimes lol
I think that sounds about right for ohms. I have a thread I just started yesterday having the same issue on my pass. Side bank. I got a new IDM to try should be here today or tomorrow. If you don't figure it out by then I will let you know if it fixs mine. If you get if figured out before I post up please share your fix !
everyone thinking idm? thinking swamps
Do you have a friend that can swap to check?
Id be looking for diagnostics. If you send your idm in and its good then undortunately you have a hvhf idm but the problem is unaddressed.
I think swamps has an idm troubleshooting procedure on their website.
No its not there...i looked
When i had trouble, i put a known good one in.
You need to find someone who can run a buzz test.
