Exporting and emailing file
Cknox121
Augusta GA
So which file do I choose? There are like 1000 files on my sd card
Can reach me at 706 496 6330 if you want to walk me through it
Thanks
Cody
Cknox121
Augusta GA
Also I went to update my SD card and it said I have no more space??
Can I just delete some of the files or should I just get another one?
Mpoage
OKC, OK
Once the files have been exported to the SD card the Mcc files should be in the custom folder.
sledfreak
south of 80
when you stick your card into the reader and export it to the computer, bring the files up, mcc tunes will be in the custom file. Also you need to download max calibration software from the h&s site to read them and adjust them,when you want to download them into the truck,put the card into your tuner go through the normal procedures-menu-download- it will give you 3 options, you want the one that says download custom tune to truck.
Cknox121
Augusta GA
Thanks
Any idea where to find engine part number?
Gear head tuning sheet is asking for it. Is this the same as the ECM? Or TCM?
sledfreak
south of 80
when you open your custom file it's listed as f64 eng mcc, and trans is f64tranmcc.also if you don't have the stock rims and tires make sure you tell what you have or you can change it in your engine file before you email it to them.Really you should call them they will tell you what to do, i don't remember filling out a paper, but that was a year or so ago.
Gearhead
Thanks
for the h&s tuning all you need to do is send us your files. No need for the engine pn (that is for the SCT devices).
