F3 R130 Procharger
Jonnydime
One of the local speed shops has a slightly used F3 Procharger for sale. I read through the Empire thread about running an F1 on a Power Stroke. It mentioned an F3 but never got in depth on it. I am by far no expert on 6.4's I was just wondering if this supercharger would be beneficial on a stock fuel factory compound truck ? Would it be similar to running a big atmosphere in front of the stock turbos with a better low end? Or would it eat up any power it made like the F1.
imelmo
Given the amount of cfm an F3 can do, I don't think stock fuel would be enough. I could be wrong but I don't think so. You'd have to slow the Procharger down so much it probably wouldn't be very beneficial.
I could be talking out of my ass though. LOL
Depending on what F3 it is, cfm could be anywhere from 3000-4000: http://www.procharger.com/fseriesspecs.shtml
kdogg85
Not to mention the entire new rotating assembly because that unit will blow the crank right out of there, would be an awesome running truck if you went that route.
WoodBoy
Alabama
Ive looked at this thread like 10 times and just now realized there as a question in it. Damn avatars
Erikclaw
Central CA
No chit! Did the op ask about tow powers or something like that?
That thing puts almost 3 times the air flow of an F1? Hope you have an engine that can take 100-150psi. LOL
Jonnydime
Well I can at least pick this charger up for alittle less than Tow Powers. If that makes a difference?
Erikclaw
Central CA
He will never get a proper answer with that avatar. LOL
There is a lot of tuning etc to get it to work right. I don't know much about adding one, and it does rob a lot of power just to make it turn.
B585Ford
WV
averages around 20% rob of power I was told
Do you have any idea how much it would rob when it is pushing the max? I definitely aint an expert on superchargers, but I was under the impression they do well down low, but really start to need a lot of HP (ie rob horsepower) to spin them when they start pushing some serious boost.
To the OP, I would love to see you try it just to see how it worked. How exactly were you going to run it...before the atmo, stand alone, etc?
Dzchey21
wyoming
only thing i can add is you should have a good cogged set up right to the crank pulley, an f3 would be bad ass
kdogg85
They do take a lot to keep spinning, but don't those put out an ungodly amount of cfm? I mean enough that you wouldn't miss what they eat up. Assuming this would be a mainly street truck, you probably wouldn't notice it. I think a twisted driveshaft would get my attention more than some power loss. :thumbsup:
BOSS450
Concord, NC
The Problem i could see would be a motor whos grossing 1200hp only netting a 1000hp. get where im going? puts extra strain on a motor that already has problems staying together at that hp level.
Dzchey21
wyoming
That was one of my biggest issues. Turbos are Damn near like free horse power. I think with an f3 you would want to turn it pretty slow. Mass air flow should be easily achieved as long as target boost is where it should be
