Few refresher questions
rat49f6
Vernon,NJ
I'm pulling an engine from a friends truck and installing a junkyard engine in place of it
Truck is a e99 replacement engine came from e99 e series bus
I know that the drivers side exhaust manifold is diffrent but will the van one work in the truck?
Ill be using the van turbo with adapter but swap the truck spider onto the engine. Should I use the van pedestal or truck pedestal? Iirc there is a difference
Sent from my SGH-T889 using Xparent Green Tapatalk 2
SPEEDDEMON31176
Carbondale,PA
You can't use the van turbo with the truck spider as they are different sizes. The van turbo is larger in diameter. The fuel bowl setup is also different on them but it will work. If you use the van turbo, up pipes, and manifolds they will all work together. Then you will need to find a spider off of a later 99-03 truck and either the plenums as well or reducer boots.
rat49f6
Vernon,NJ
I had an e99 van turbo on my e99 sd and used the e99 truck spider...I know that will work
rat49f6
Vernon,NJ
I thought I remember the manifold being different on the drivers side...will it clear everything in the truck chassis?
