Buffalo444
How much does a flow bench cost and where would you get one? Is it possible to build one at home?
Commercial units run about $30k
Yes they can be built, but they still are not cheap. It is no where near worth wild just for your own or even a dozen sets of injectors to recoup the cost.
it is basically one cylinder head with the necessary Electric driven pumps for fuel and oil and electronics to control it, and a way to measure the fuel that comes out of the injector tips
That's basically it besides some temperature stuff, the fuel and oil should be at normal operating temp.
what are those temps?
I'd call up an injector shop tomorrow and talk to them, maybe they'd give ya some advice. I'd say the most challenging thing would be the electronics.
Well normal oil temperature is 180-200*, i'd say fuel would be room temperature it will heat itself some going through the head.
192-195* for oil. I am not sure about the fuel though. Maybe someone will chime in with that info.
I agree. I think building it is feasible for the average Joe with knowledge on how the system works, but controlling it would be a different story.
Thats what I'm thinking too. But I figure as long as I could get some sort of set up to launch 1000 signals to the IDM and hit the solenoid 1000 times, then it should be doable.
I think I might give it a whirl. Need to find a junk 7.3 head to lop off a chunk, but other than that I think other stuff should be manageable.
Why chop up a head? Seems like that'd be making a lot more work for ya.
Just lop off one cylinder. if not, I have to plug the other three injector holes.
