Fuel system build
strokin6L
Springville NY
these clamps i think he was referring to...
smokinstroker
Texas
What lift pump were you using?.
i had no lift pump,
sump>filter>fuelab>filter>RR
pump only saw failure once it hit water, (rain, car wash etc.)
talked to fuelab multiple times, assured me it was fine as a stand alone pump (needed no supply pump as long it wasnt doing a heavy pull) as well as ensured me that the pump was 100% waterproof.
i was told to use dialectical grease on the electronics to keep out water.
Josh@DirtyDiesels
PA
i had no lift pump,
How did that setup work once you got your pump issues figured out?
strokin6L
Springville NY
Fittings on the heads are 12mm x 1.5 o-ring and usually go to-6 AN for the fuel line.
Garrett
probably getting paid at work to post this from my bionic
thanks Garrett. Thats what i was gonna post, but didn't want to cause i wasn't 100% sure if i remembered right haha
smokinstroker
Texas
setup worked great, a member on here now has the new pump. they always stood behind the pump, and warrantied no questions asked.
held full pressure with 205/100s
Josh@DirtyDiesels
PA
Cool. I might end up going that route. not sure if it really makes sense to spend an extra 600+ on an AD or FASS just to feed the real pump...
smokinstroker
Texas
be careful if you are not using a pusher(feed) pump to your hp pump. some claim that to be the failure with many of these pumps not living long.
