fuelab pump issues again
Merc82
I run a sump feeding a 6.7 pump to a CAT fuel filter to the back of the heads to a Fuelab regulator and back to the tank. I return through the pump and to a bulkhead on top of the tank. All 8AN lines, except the lines to the heads and to the regulator, those are 6AN. Pretty pleased with the setup.
swinky
Eastern, Nc
Next time I'm in Florida we need to set mine up like that.
Extended Power
That's a lot of rules for getting the same job done as my setup with simple 1/2 rubber fuel line to the factory bowl and a standard regulated return.
Like I said...take it, or leave it.LOl
Sealeveloc
Berlin MD
I've been running my fuel lab 41402(big boy pump) for 3 years+ with zero issues. sump, -10an, 30 micron, pump, 10 micron, -8an, y block, -6an to the heads, -6an RR. Its loud but doesn't bother me.
swinky
Eastern, Nc
Nobody cares asshole [emoji23]
cboger
Happen to have a part number for the adapters you used?
Sent from my Nexus 6 using Tapatalk
Merc82
EFI adapter fittings? Yah, I got a parts list and a writeup on the ORG. I got to edit it a little, since I changed the way I routed the hoses on the filter head. I ran into some issues by not using the return on the pump. Works great now. Swink's writeup is pretty good on here, referenced it for my install.
http://www.powerstroke.org/forum/6-0l-performance-parts-discussion/992922-my-6-7-fuel-pump-instal.html
[/URL][/IMG]
cboger
Awesome. Your just using the factory 6.7 filter and that cat filter correct?
Merc82
Yessir. Also, if anyone has the part # for the WIF sensor pigtail, let me know.
