Next time I'm in Florida we need to set mine up like that.I run a sump feeding a 6.7 pump to a CAT fuel filter to the back of the heads to a Fuelab regulator and back to the tank. I return through the pump and to a bulkhead on top of the tank. All 8AN lines, except the lines to the heads and to the regulator, those are 6AN. Pretty pleased with the setup.
That's a lot of rules for getting the same job done as my setup with simple 1/2 rubber fuel line to the factory bowl and a standard regulated return.
Nobody cares asshole [emoji23]I've been running my fuel lab 41402(big boy pump) for 3 years+ with zero issues. sump, -10an, 30 micron, pump, 10 micron, -8an, y block, -6an to the heads, -6an RR. Its loud but doesn't bother me.
Happen to have a part number for the adapters you used?I run a sump feeding a 6.7 pump to a CAT fuel filter to the back of the heads to a Fuelab regulator and back to the tank. I return through the pump and to a bulkhead on top of the tank. All 8AN lines, except the lines to the heads and to the regulator, those are 6AN. Pretty pleased with the setup.
Sent from my Nexus 6 using Tapatalk
lamo, eat a dicNobody cares asshole [emoji23]
