Help, carli leaf spring install
jaynick1
Texas
So I am installing the passenger side, or trying to, and turns out the eye to eye length of the carlis I was sent are about 6 inches shorter than the stock ones, yes i installed the stock shackles as well. Obviously they wont line up. Did carli send me the wrong leafs? I know the 05-07 length is shorter. Truck is in pieces right now and I am a bit ticked off.
Zmann
it does sound like they are wrong
unless they have a big arch and need to compress to flatten out since they ride so plush
i don't remember needing to do that with Deaver /Carli
is there a part # on the spring pack ?
05-07 is like 8" shorter
Zmann
I was just looking they are supposed to provide 15" of overall travel if you have the long travel upgrade
they may just need to be compressed
maybe a part # can clear it up ?
jaynick1
Texas
I was trying to compress it a ton, and it would barely budge. I thought they would go right in and werent preloaded. Theres no part number on the deaver either.
Zmann
that sucks how do they keep track of whats what with no part # ?
maybe they don't LOL
you will need an eye to eye measurement and a phone call
not what you wanted to hear I know
Zmann
I bought a set of " Barely used " Deavers they even had a part #
I know because I had to call them and ask why the tire sat so far back and the lift was not close to what it was supposed to be
the Deaver guy " Scott" pulled up the # and told me they were ten years old
and apparently worn out LOL
Swampfox
TN
How much difference were they from the driver's side? Call and talk to Dan at Carli, their customer service is great.
Zmann
I figured He started with the pass side and din't get as far as the drivers
I agree Dan will get him situated
Swampfox
TN
Yea I wasn't sure if he already had one side in or just started on that side. I would highly doubt you would need to compress a brand new spring to get it to fit.
jaynick1
Texas
Yeah I started and didnt get to the other side. The compression i would need to get them to fit os a bit extreme. Hopefully Ill get it straight tomorrow.
jaynick1
Texas
Carli comfirmed I have the correct part number. Now I have to figure out how to straighten them out enough to get the rear bolts to line up. Any ideas?
04cr450
harford county, maryland
I have a fork lift with a 750 lb weight lol (joking I used this setup to "unkink" my truck when it was uneven side to side). In all serious- spring shop will take care of it
Betarocker
Sea to Sky, BC
Straightening the arch before install will change the spring rate. Without knowing the tools or equipment available, one could use some heavy c-channel to hold the spring in a compressed state. Just need to figure a way to compress the leafs safely.
jaynick1
Texas
Got them installed finally, and all I can say is wow. Amazing ride quality. Almost feels like a half ton.
