Help help help codes no power please
dsberman94
Pennsylvania
Hell. Though I caught a big for a while but it was just allergies. I feel for ya. Definitely no need to do it tonight. It's gotta be almost 10:30 there atleast.
Gearhead
why are you pulling a vaccuum at idle, that's what I want to know. The tunes you have shouldn't do that.
TXlineman83
Austin, TX
I really appreciate all the help you have been giving me. According to what I've shown you with my programmer I'm getting full fuel right.
TD-5
British Columbia Canada
So the MAP sensor shows a vacuum at idle & low boost at WOT ( around 30psi)?. Possibly a restriction between the turbocharger outlet & intake manifold inlet. Maybe they had a rag stuffed in the hot pipe when things were apart that never got taken out, now its down at the inlet to the CAC causing a restriction?
TXlineman83
Austin, TX
Idk. Guess it couldn't be too hard to find out.
TXlineman83
Austin, TX
Went to ford dealership. Got some old grumpy set in his was diesel tech who swears I ruined the motor deleting it and that it's my sct programers fault truck is not running right. Gonna try different ford dealer. This 7 MPG sucks.
Csilva187
Did you leave bad terms with the shop that did work? Dealer is gonna be a nice bill, always is...
TXlineman83
Austin, TX
No. Shop said if I can't figure it out they will. No concerns there. Only reason thinking dealer is IDS diagnostics. I think that's what it's called
BFT
southern cali
P0113 Intake Air Temperature (IAT) Sensor 1 Circuit High
Sensor is probably toast. Can you monitor intake air temp?
