Help help help codes no power please
TXlineman83
Austin, TX
Engine temp 194
Engine Oil Temp reads 92
Iat2 reads 36.77
Iat1 reads 86.00
That's tight this very moment
Outside temp is 77 degrees
B585Ford
WV
I hated trying to monitor with the SCT. I know EOT is degrees C and ECT is in degrees F. I can't remember, are both those temps in degrees F?
TXlineman83
Austin, TX
Ok so have shop with IDS on the truck and everything seems to be reading normal. No codes are being pulled. Swapped out IAT and MAP and still having same problem. Fixing to pull these JR high powers off and reinstall my stock compounds if something don't come up soon. Eliminate the only thing I've changed.
if you pull the turbos off i can almost guarantee the problem will still be there.
have you changed the rail pressure sensor yet?
on the IDS, try and ramp the rail pressure up
TXlineman83
Austin, TX
Yes. FRP sensor was changed out to a new one. Ramped it up on IDS and still same issue it seems. No boost on low end. I know bigger chargers will be laggy somewhat. But I still can not boost launch over 1000rpm
bigrpowr
<How I Fly
Administrator
If I were you I would have given it back to the shop I paid immediately.
