hpfp problemss
twitch02x
Houston
I just loaded the hd300 and fuel on 5 and now at wot I'm only seeing 20,000 rail pressure, at idle its at 5.1?
When I'm on the throttle 75% or harder the truck has been pulling hard then just flat out falls on its face for a sec, like a east legate opened and loses all boost then when you get off throttle its OK. Check codes and nothing there. This has happened twice now. Seems like rail pressure was good with the 250 tune and fuel on 3
Any suggestions
webb06
Seneca, MO
How many miles on the truck? Sounds like the HPFP can't maintain high rail pressure. The high the tune the more fuel it commands, thus why the truck loses power on the higher files.
CT9AIX
MA
When was the last time the fuel filters were changed? Maybe got some crap from the bottom of the tank that really clogged them up.. or the LPFP dying out not feeing the HPFP what it needs. Try the easy stuff first.
