Hydra switch mount...
CSIPSD
Bend, OR
Working on this still but getting closer...
This was a few weeks ago...
Then I made some adjustments last night...
Once I get home I will tack weld a small piece behind the switch itself so that you can remove one of the screws to hold it onto the mount.
Thats one thing I did not like about the old DP mount, it stuck out in front of the gauge.
Also will be working on a gauge type mount as soon as I can get down to portland and pick up some parts from Michael.
PSD715
Alamogordo NM
That bothered me also.
The new mount gonna hide the cable?
CSIPSD
Bend, OR
I dont see how to hide the cable with the side mount, but when I build the gauge cup one it will... Hoping to get the guts of a switch from Bill.
CSIPSD
Bend, OR
In my case I will more then likely put it on the steering column mount, simply because my scan gauge is about DOA so I dont need it anymore.
Pwnm30rdi3
Indianapolis, IN
I like the way it looks.
But if your looking for a solid piece, I've had some great luck with fiberglassing.
Look up some how-to's online and fiberglass a nice mount built into your gauge pods. I'd be more than willing to fiberglass and paint something for you if you were to hot glue it into place, kinda like a template.
superduty4x4
Newport, WA
Joe, have you considered using ABS? With some heat I think you could bend it without stressing it and having problems. I have a bunch of 1/8" ABS sheet if you want a chunk to play with.
