Mike@MPD
Ben from Rudy's pulled with a 2.6 bulls eye with no bars or weights in the 2.6 class and pulled 368
Sent from my Galaxy Nexus using Tapatalk
I'm working on the same thing As you twisted stroke. Trying to do the same thing but I'm trying to stay in the 2.6 class. I would have way to much in it, and to many people in the 3.0 class around here. im very interested what you do decide to do.
No love for the GTX series on the 6.4s? Ive yet to see one? Pretty sweet 3.0 turbo if you ask me, anyone have a compressor map for a bat-mo 475?
where are you located at
Ohio.
hope you bring 1,000 plus hp in 2.6 - i'd like to see it
i know they are making 1200 plus but i have no other choose in less i use a plug on the charger
According to track times the 75 does 1050 on fuel .... Also keep stock cam as no one has proved any gains from cams.. Ported heads probly aren't worth it either I have stock heads and intake on mine
1100 + for 2.6 1400-1500 for 3.0 I recommend def a manual tranny and a hx60 or a good precision ball bearing charger if I'm gonna be serious about pulling
In the pulling world you can run clipped wheels rather then bushed turbos. Most are running way over 80mm wheels just clipped to meet rules.
Missing the reason behind cam profiles.... Moving the hp and trq to where the truck is ran on the track is extremely important on a pulling truck. Now take a ported head and match a cam with it and you have an even better performance gain in the end. To many people will buy a said cam and have joe blow port and polish (which polishing is the biggest snake oil one can spend time and money on) a set of heads and expect gains. You can have the said best cam profile and highest flowing heads and if they are not designed to co exist together you wont see benefits and in most cases end up going backwards. To run at the 3.0 level you need go past bolting parts on and expecting results every time.
Exactly.... You wont see the Batmo hype running on your top 3.0 trucks in the country. HX60 with proper upgrades for similar $ to a batmo will put down larger numbers every time... and stay in one piece.
