In Between Fords
FTKRayJr
SoCal
So I haven't done much with the Superduty other than putting a bunch of miles on it. My Dodge has been parked so I decided to finally show it some TLC and bring it back to life. I have a Superduty Build planned for SEMA but this project is a filler. I'm shooting for it to be complete by the NHRDA spring nationals in Bakersfield on the 22nd. Truck is getting tore down to nearly the bare frame and gone over. I have put a ton of miles on this truck and I am wanting to continue to drive this thing everywhere. A lot of racing is in store this season. Started on it the other day and this is where i'm at..
I am tearing into the engine today and also rolling the frame outside to pressure wash everything. I converted it to an automatic and never finished looming wires because I always had the want to move the fuse box and batteries. I had a turbo oil feed line crack and everything got oil coated a while back. That was when I decided to let the truck sit and address everything at once.
FTKRayJr
SoCal
One thing hat has always bothered me was the holes in the frame. I took the time to make pieces and weld them shut
Frame stuff
Drying tonight and back at it tomorrow! I am going to prep the engine for paint and go over misc brackets for paint.
FTKRayJr
SoCal
Thanks Matt!
Reassembly is in full swing. Got the tank in
New rotors and pads. Blasted and painted the brackets. Cleaned, restored, and painted the calipers
Swapped out the trans filter
Quick Spray on the trans case
Painted the block and bellhousing adapter then set it in. The engine mounts are tore so I ordered up a set of prothane inserts that will be here tomorrow.
Set the trans in
I also ordered $900 in AN line and fittings which will be here tomorrow also. After work today, I will be painting a bunch more and moving right along!
FTKRayJr
SoCal
Well my deadline was Saturday. I worked friday 7am til saturday 9am and got everything done for the event that was actually that day. With the exception of a few things i'd like to get done, it is mostly complete. I need to build a coolant res tank and finish up some wiring for accessories then build the roll cage. Now for my MAJOR set back. The truck was complete and ready to start at 9am. I got in it and primed the fuel system and shortly after cranked until it fired up. With AN hose for everything fluid related on this truck, I anticipated some type of leak somewhere. The first was the turbo drain on the atmosphere turbo. The bolt holes aren't centered with the drain hole so the offset caused a leak. Now I modified the old drain with a -10 AN bung so I had the wider flange to fix that issue. Next was a small trans leak from the rear trans cooler line inlet on the trans. I let that one do it's slow drip while it ran for a few minutes. I then went underneath and there was trans fluid all over that area. Assuming that the fitting was loose I gave it another half turn which was pretty tight and left me suspicious. Truck then started right up and it leaked more. At that point I had a pretty good idea of what was wrong and crawled underneath to find a hairline crack in the case. I tried to JB Weld it just to get by for the day until I could tear it apart and weld the case this week but had no luck so I left it at the shop and took the superduty to the event. Here are some crappy cellphone pics of where it's at now.
MINK
London,OH
Thanks bud, I was debating for a long time on what to go with until I saw this color was released
Thanks Mink, on a side note..I might have a Nashville trip planned for May with some people if y'all are interested
duhhh...I just stopped into our favorite place friday on my way down to baton rouge LOL
