Irates full fuel system
big johnson
Nokesville, Va
Has anybody run it before? Im thinking bout upgrading the fueling system on my truck and think it might be what I need to go with. if anyone has run it what are your thoughts or is there anything else I should look at?
ToMang07
Mainah!
I haven't installed it yet... but it is a very nice kit. I can't wait to get it on the truck.
OSCS
Houston, TX
I have a full setup 5/8" pickup tube and all it's a great setup, quality stuff. Do you have a CC or super cab? I ordered a kit for my super cab and ended up having to mount it in a different location due to his bracket being off. Not to mention he didn't send any mounting hardware.. Just be very thorough when you order it and make you sure you get what you paid for. I'm in no way bashing Irate diesel just Sharing my experience. Great product though
big johnson
Nokesville, Va
when yall put it on did it make a huge difference from the stock fuel system? or what exactly did you notice from doing it?
bruce
Middle east
stock will support those injectors, do a regulated return with fuel bowl delete, find a filter base, i would do a sump.
OSCS
Houston, TX
If your going to do a fuel upgrade system like this you might as well do an RR man. It makes things SO much easier to work on under the hood with the fuel bowl gone not to mention far superior filtration
4.0l sahara
shelton,ct
OSCS
Houston, TX
Wasn't sure you bought the one including the RR I posted before the pictures where uploaded
big johnson
Nokesville, Va
ok cool. so this may be dumb question but what exactly is a full fuel system do? I understand that when you upgrade injectors turbo etc you need more fuel and not lose pressure but is that really all or woud I notice anything like gains in power, more smoke? better or worse fuel mileage? Im just trying to fully understand it
4.0l sahara
shelton,ct
to support larger injectors and eliminate the "dead head" in the factory fuel system in the heads.
