nickg3130
Sorry if I missed it but what are the specs on the exhaust side of this turbo?
Not elite but as many of you may have seen RCD went 7.60-7.70s with 72/74 and swapped to a 75/77 and went 7.45@92.
Size: Good for spool up and power.
JD's truck impresses the hell out of me with this turbo. I'm excited to see what comes of the 59vgt testing coming up
Is the housing bigger on the exhaust side or no?
No it's not. Stock housing.
big difference from a reg cab to a cc though. bout 1000 lbs.
Josh had claimed his truck was 7400 tho. Which I could see being on 35s and road Armor bumper ect. Mine was 7140 @truckfest
Sent from my SCH-I545 using Tapatalk 2
Think JD tips in over 8100 iirc.
Everyday driving around I'm right around 8400
I dont care if its reg cab or crew cab. All I was referencing was the difference in times with the 72 compared to the 75. Times between the two trucks whether they be reg cab or crew cab with only change being atmo charger from 72-75 or 76mm in this matter should still net the same gain.Yup. Long way off of a 7400 lb reg cab lol
So your saying that being JDs truck is a crew cab he wont cut off .15 in ET or close to that with only change in being the chargers? That is what I was getting at. Granted it was a diff day/night. Or a I not thinking correctly here..
I'm confident JD's truck would run slower switching to a 75. That's been proven in testing. If that's even what you're asking
Approximately pegged gauge psi. Lol
I never watch boost. 50 or so.
Lol priceless statement
