KEM tuning
ohiostroker95
Mount Gilead Ohio
I'm in need of new SCT dpf/egr tunes and i came across KEM. Was wondering how good their custom tunes are. Would like someone that has them or knows someone that does. Thank you!
Cfox17
Knoxville
I have not ran either of these personally, but I have always read and heard great things about Innovative Diesel tunes and Gearhead tunes. They seem to be the two leaders of the pack.
I just got my truck tuned myself and I'm running a mini maxx with the hot damn tunes and I'm about to MCC unlock and get some Gearhead tunes myself.
fine69
Cranberry Twp,PA
I have the special edition sd card tunes from KEM, my truck hates them! It doesn't shift well on any of their tunes, I've gone back to the canned H&S tunes until I can get some custom tunes from Gearhead.
patrickpsd
wisconsin
I have RCD and innovative tunes. Haven't don't much with the innovative but the RCD shifts nice and is very street able. Going to be doing some testing on a few dif tunes this weekend
patrickpsd
wisconsin
I didn't have any Kem tunes but here's what I came up with after some testing Saturday. I was looking for all out power for pulling. But as far as trans tunning goes there all decent. RCD is about the sofest shifting of all of them. Will be doing some more testing at the track soon to get 1/4 times from them
Tune testing today.....
Wanted to actually see for myself what tune is better with a side by side comparison of 5 tunes on the same day on the same dyno with the same setup changing nothing but the tune. Was sick of saying gearheads better or innovative is better without seeing any proof so $500 later I got satisfaction.
59/76.7 turbos and 60% nozzles
Super flow top of the line load cell dyno
Made at least 2 runs and each tune back to back and each time the graphs were damn near on top of each other. Dyno repeated very nicely.
I don't want any negative comments on how dynos aren't accurate you want to see track times. Its still a side by side of each tune. All engine. No trans or launch or driver variables.
First run was gear head 716/1398
Second was RCD 651/1329
Third was innovative 646/1223
Fourth was spartan 350 742/1497
Fifth was spartan 310 729/1537
Also did a run pulling 2 rear duals off dropping 320lbs in roaring mass. Did not make any diferance what so ever.
Have only run the RCD tune on the track. 9000lbs and a 12.925 at 102mph. So that's damn close to the numbers off the dyno
patrickpsd
wisconsin
Thanks. Ya I haven't seen anyone do it yet and I wanted to know for myself so finally just went and did it
Gearhead
Was it downshifting on our tunes? I hate the fact that my tunes don't dyno well because you can't get full spool sometimes because the trans will try and downshift... I also keep the smoke control very tight so if the turbos aren't fully lit, you won't get full fuel.
patrickpsd
wisconsin
No it didn't downshift. I can send you the graph and the data logging if you like. Not sure how to post pictures on here. It was boosting about the same on all tunes. 55ish psi. And you can at least say yours dynoed the best off all the "custom"_ tunes
ckrueg
Belding MI
That's interesting, makes sense the rcd and innovative are lower but odd how the 350 is lower pw than the other 2 yet made more power.
johnp115
Southern MD/Charlotte NC
Yeah my truck constantly dyno'd 30-40ish hp lower than track times would and be 8-14psi low on boost.
Great work though dyno-ing back to back. We need more of that in the diesel performance world. It is a tough task to do unfortunately though
patrickpsd
wisconsin
Ya I agree but I'm sure there's more factors then just PW. I'm sure injector timing plays a factor. And some other variables
patrickpsd
wisconsin
Great work though dyno-ing back to back. We need more of that in the diesel performance world. It is a tough task to do unfortunately though[/QUOTE
Ya I was surprised I haven't been able to find anyone who's done it. Kinds sucks spending money on different tunes just to test them. But at least now I know. And data logged everything in case these company's wanted to look at anything and try and improve on stuff. Would a liked to have something from Kem to.
