low pressure fuel system
GROSSpolluter
So Cal
i finally got around to setting the pressures on the airdog and the fuel block. the problem i have is with the airdog at 10psi i can only get 8 psi at the block. then if i bump the airdog to 15psi i can get 12psi at the block but after the truck warms up it can be anywhere from 10psi to 6 psi and fluctuates randomly. not while sitting there. whenever i get fuel ill pop the hood to check on things and it will be at a different pressure at different times. does this mean my airdog is on its way out or is this common?
GROSSpolluter
So Cal
Yes I have a gauge in the regulator on top. But I just used a hand held gauge for the airdog. I'm going to thread one In and leave it on the Airdog once I get one.
GROSSpolluter
So Cal
blk350on20s
Wayne said a while back to turn your air dog up and regulate the EDE regulator at 11 psi. Basically the only regulator you want in the system is the engine mounted one
