GROSSpolluter
i finally got around to setting the pressures on the airdog and the fuel block. the problem i have is with the airdog at 10psi i can only get 8 psi at the block. then if i bump the airdog to 15psi i can get 12psi at the block but after the truck warms up it can be anywhere from 10psi to 6 psi and fluctuates randomly. not while sitting there. whenever i get fuel ill pop the hood to check on things and it will be at a different pressure at different times. does this mean my airdog is on its way out or is this common?
