modifying an HPOP to spin backwards?
m j
BC Canada Eh!
pondering modifying an HPOP to spin backwards over my morning coffee.
is that simply clocking the swash plate 180° out or am I missing something?
m j
BC Canada Eh!
looking at the options available
a system that uses readily available, stock-ish, pumps will be more serviceable in the future
DZL JIM
North East Ohio
Inlet and outlet passages will be backwards. You just can spin it backwards cuz you want to.
BTS used to use a stock 530 pump on top, an off-the-shelf unit if you want to use off-the-shelf parts.
m j
BC Canada Eh!
do you mean backwards in the casting?
if you spin the swash 180 out of stock, the pistons will be drawing down and pushing up correctly, that or I need to look at it again
