Monotherm pistons
juniort444e
Slippery Rock, PA
I see Mahle is making these for other motors. Anyone know when they will for the 7.3 and if its worth it. Diesel power sure says they are the Bees Knees. I would like to try something different than everyone else, before they become popular. And if they are lighter than the aluminum ones and stock ones and can handle heat then it seems that they are a good choice for my build.
91turbogsx
Gardner MA
Call Swamps and find out what these will go for...
juniort444e
Slippery Rock, PA
http://www.automotiveproductsfinder.com/Articles/AR2005/NOV/Steelpistons.asp
The Monotherm piston is made of a single forged piece, which means that, unlike the Ferrotherm piston, the piston skirt is formed as one part together with the pin bosses and piston crown. This results in significant advantages: Connecting the skirt to the pin bosses leads to a larger available bearing area to accept the highest peak cylinder pressures. The piston pin no longer needs to hold the piston skirt, so it can be shorter and lighter. Extremely compact dimensions are possible. For example, a compression height of only 50 per cent of the cylinder diameter can be achieved. The thermally stable steel skirt reduces friction; reduced fitting clearances lead to a better guidance of the piston. The guiding quality of the piston, especially in the ring area, results in better levels of oil consumption and blow-by. In addition, the Monotherm piston includes high rigidity and long life. This type of piston combines a maximum mechanical loading capacity of up to 250 bar with other important criteria such as lower fuel and oil consumption, lower noise level and less weight. While the first engine with Monotherm pistons already went into volume production in North America in construction equipment in 2000, the weight-optimised design has replaced an aluminium piston without any increase in the oscillating masses of the piston and pin.
Bean
Mahle is now working on Dmax Mono's and once those are done they will probably go to the 6.7's. I doubt they ever do 7.3's and be a long time before they get to the 6.0/6.4 piston. Mahle is a very high OEM production place and these hi-po pistons are very small short runs so getting them done takes allot of time just waiting to fit the short runs in between the huge oem runs.
Mono's are heavier then a cast or forged aluminum piston but not by much once you add in the wrist pin wieghts.
If you really had to have a set they might do some from billet but expect to pay probably 4k+ for a set.
91turbogsx
Gardner MA
This is a steel piston for those that don't know. Can't wait to see the price! Hopefully "affordable" and not complete unobtainium. Been planning on building a block for a long time and seems things may be coming together. :evil
