Motor Build - Finally!!!
6.0L Stroker
Southern Illinois
You guys definitely make it interesting to follow along in these threads. Looking forward to seeing the results
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
bigrpowr
<How I Fly
Administrator
For ****s and giggles do you remember the exact HP and boost it bent at?
it was back pressure that did it. we had made some changes to the duty cycle the night before , then nathaniel and i went out hot rodding it to put fuel in it not knowing that tadd had put that tune in. on the dyno pull when it let go it was on a skyward pull to 1200 and started sounding like a slot machine. iirc 85-90 psi .
tensixniner
Did i miss something ... How does backPressure bend a rod?
bigrpowr
<How I Fly
Administrator
you missed that in physics class. just think about which way forces are applied. boost applies it one way and bp applies it another. boost was 85-90 , bp was 140 . same way bp can blow a headgasket.
tensixniner
I can see how 140 psi of backPressure will hold valves open.
A rod that can take several thousand psi of combustion pressure being bent with only 140 of back pressure doesn't make sence to me.
Won't boost and backPressure both be trying to push the piston down?
powerstroked08
Pennsylvania
That's what happens. The bp is pushing down and the crank is pushing up and bingo bent rods.
