MPD budget single turbo kit reviews?
Sequential6.4L
If a guy wanted to spend the money a diverter valve could be an option, I have zero expirence with them but a guy from Jefferson state diesel told me hes done a couple single 72 6.4s with a diverter, said they spooled like a stock truck.
Strokin6.4
Where does a diverter valve go? And what does it do lol
Dzchey21
wyoming
There is an alternative to the bd but I can't remember right now who makes it. Its made for diesels
madman1234509
mayfield, ny
If a diverter valve is anything like one on a gas engine. Its basically the same concept as a BOV. But instead of blowing off the access boost into the atmosphere, it blows it back into the intake system, between the air intake and turbo so you arent loosing the air that was already brought in.....
Unless there is a completely different diverter valve for a diesel :p
Gunnnin
Is the diverter valve you guys are talking about the same as the spool valves that cummins guys are using to quick spool very large singles?
SEABEE08FX4
Montgomery TX
Wayne
Twin Falls, Idaho
I know of guys blowing the diaphragms on the diverter, causing excess drive pressure, and major engine failure, but if pressure to the diverter is regulated, there should be no reliability issue. It's a very simple mechanical piece.
Sequential6.4L
yeah the sdx quick spool valve, i know alota duramax an cummins guys swear by them an ive also heard of a few failures like them sticking an what not, if you have a tuner you can set a back pressure alarm with that might be a good idea in case of failure.
simonton6.4
Monroe,Ga
Correct me if I'm wrong but the biggest thing that holds me back on doing a single 66 is I can Make the same power with stock turbos as I can a single 66 I do agree that eggs will be higher with the stocks but i do like that it is nice that if u want more then all u have to do is buy a bigger turbo because all the piping will already be done but at the same time stepping up in turbo size ur loosing the towing ability I think I can spend the same money and buy a atom and make more power and still tow with no worries at all
simonton6.4
Monroe,Ga
Not knocking there kit at all it's a great set up to make big power cheap but just not for everyone as we all know
Gunnnin
True however I can easily change turbos in a single setup depending on situation. Example is run a 66 on the street and then step up the tuning and place a 75 on it for track duty. Or at least that's what I'm thinking.
Wayne
Twin Falls, Idaho
Flat rate time on a complete stock turbo swap is 4.6 hrs, assuming, of course, that you don't have to fight frozen bolts. That is coincidentally the same time it should take to swap in any stock based upgraded turbo configuration. I wouldn't consider 1/2 of a day's work an end of the world situation if an additional turbo swap is necessary. I have a hard time understanding the "it's easier to work on" argument deal especially because I figure the idea is to not need to work on the truck.
Another thing to consider is your approach when you temporarily need more air than your existing setup can provide. You won't find me packing a spare larger turbo setup in my back seat for when I hit the track. When I find myself in that situation, I go this route:
Opening a valve, and turning on a switch is a little easier than swapping out a turbo. Just sayin'. If it's the aggressive exhaust note you're after, a single turbo sound is hard to beat. The only crazier sound I could think of in a semi-practical configuration is a supercharger setup with no turbo to inhibit sound, but nobody has made that much of a success to date, at least on a diesel pickup.
Don't get me wrong. I'm not here to pick a fight with anyone. I'm just trying to point out some options to weigh for each person looking at this kit, and similar options. A single turbo conversion does have it's place. We all have different tastes, and priorities in drivability, power level and curve, sound, product price, need to be unique, and ease of doing the work. To the OP: be sure to let us know what route you take.
Gunnnin
I agree nitrous is easier than switching turbos but my track is normally 300 foot of dirt. Local brush pulls don't care what size of turbo but do care about no injectables. So I think in my case a single might better for me.
Sequential6.4L
i believe the 66 single makes more power then stock, should put you over the 600hp mark i think there were a couple guys that dynoed 620-30 or something like that, mpd needs to chime in. im not saying the single is the best option just seems for some like myself it gets you the big numbers for the best price, while maintaining some drivibility. i think for around the 600 mark an atmosphere upgrade cant be beat.
91turbogsx
Gardner MA
Cost was the most important factor to me. I had a budget, and a HP/1/4 mile time goal to meet. A set of upgraded drop in twins would've ate 3/4 of my budget alone.
I can understand the CO guys being more biased to upgraded twins due to elevation. I wouldn't even consider bringing my truck out there.
Matt
Minnesota
If you are after big power on the cheap, I'd say it's the way to go. For less than 2k you can have 900hp worth of air with a box stock s475 and their new mount.
