smokinstroker
So basically by the sounds of it -12 is the way to go with all this. Just gonna hunt down a cooler from Summit now and starting trying to fit things behind the bumper.
Whats everyones thoughts on the parker push lok hose? Its easy to work with and has a 300psi working PSI, just need to find out the working temp?
Push lock is used very often, make sure you seat the hose all the way on. Any hydraulic shop should be able to set you up with some fire sleeving for the engine bay which may be a good idea around metal or high heat areas.
