madman1234509
Pretty good boost to bp ratio. Shut it some more, no reason you can't see 70-75 psi absolute back pressure( with 14.7 added).... heck a lot of people see that with stock chargers. Sounds like it's gonna run like a BEAST
I took it to the track tonight, still have not moved the gate but she ran good for the way the gate is. I will try to get it moved to where it should be soon, I have just had too much going on. A bunch of us decided to go to the track so I ran it a few times. Best pass was 7.68 @ 90.03mph with a 1.72 60ft.
I have 6in lift 35 tires and still had the spare under the truck. We did pull the tail gate, and my brother was riding with me. That pass I saw 56psi boost (till the gate opened early) I'm too tired to watch the data logger again to figure the #'s out. I had major traction issues with the tires even at 35psi front and 30 rear.
It got lots of attention! I cant wait to get the thing dialed in perfect when time permits. She still has a good bit more in her I just didn't want to hurt anything or push it too hard till I get it right.
Finally a video...so you guys will know this is not all just in my head...LOL.
http://www.youtube.com/watch?v=ohnjIo7KTRs&feature=youtu.be
http://www.youtube.com/watch?v=dGtlSOoq5sA
Update; I had a small coolant leak and found some coolant in the oil on sunday. Just a little on the dipstick looked milky. I pulled the cab yesterday and removed the front cover to find cavitation. I reused my old front cover as the reman motor came with one but it has a stripped hole in it. It looked fine so I thought it would be good. When I broke the motor in I only put 1 gallon of coolant and the rest distilled water in the truck, ran it for about 25-30 miles and flushed the system. Then I put 3 gallons of Ford gold in and distilled water in. Im not sure if the coolant being so diluted caused this or if the cover was just on its way out but I'm glad I caught it right when it happened.
While the cab is off I'm gonna re work my waste gate and up pipes also.
