my build
pog
psa
I plan on running kem 310. Seems to be stronger then the 345 from what people say. I will load it up today and play around it. I havent tried 310 yet only 345.
Dzchey21
wyoming
if its anything like the old spartan stuff (which it should be since thats what the old spartan stuff is) it will be a tad smokier but it should make more power
pog
psa
Wooooooo morre smoke :D no emissions here. Im really hoping my failing tranny will pull me into the mid 13's. Elevation i think is 25ft
Dzchey21
wyoming
Wooooooo morre smoke :D no emissions here. Im really hoping my failing tranny will pull me into the mid 13's. Elevation i think is 100-150ft
should run 12s depending on how pissed that trans is. You might be able to have mike firm up the shifts a bit if its slipping
pog
psa
Shane i talk to the boys over at dtt.. They are standing by the life time warranty on the goerend tc. He said the life time warranty is based off that they assume another part of the trans will fail before tc. But he said if it starts slipping its replaced. He quoted me just under 2k with rebuild kit and tc. Another 295 for billet input shaft and 450 i think for low reverse hub. Sounds like a good deal. also he said will handle way over 600hp which im not even in.
12's would be awesome. I dont even care if my tranny blows up after a 12 second run lol. I do wanna make bd dyno days though the next morning
pog
psa
I will def be going this route. Now to save up for a few weeks lol.
pog
psa
Im glad i could help you out man. I would never be able install it on my own so it would just collect dust.
pog
psa
well hit the track tonight.. did 4 passes. lowest time 13.829 highest 13.915. my tc is facked. no top end power. everytime my speed was in the 94mph range. quickest reaction was .227 highest .856. 60' lowest 1.859 highest 1.916. i keep getting a p0003 code. im hoping my wg just needs to be turned down. highest boost i logged was 37.8 and ep @ 75.3 ( about 60-61 absolute). something about fuel volume regulator control circuit low. i was hoping in low 13s. first time at the track though, tire psi was @ 45 all the way around.
pog
psa
It only happens on hard pulls i think like 23k frp and up. Dont know exact numbers. Ill try adjusting wg in the morning before bd
Dzchey21
wyoming
your mph is pretty slow, like the power is falling off, unless the trans is slipping that bad
You should be 100+ mph for sure with what you have done
Whats your rail pressure sitting at?
boost should be higher too i would bet
