DieselMater86
2003 dually just had motor bulletproofed. Drove maybe 20min no problems went to a meeting came out had a oil leak I made sure to park in a clear spot. So check oil good and got back on interstate all of a sudden black smoke from out of nowhere and I'm talking BLACk badtruck died. Starting it back up had to crank a bit then started run for maybe 30 seconds and died. Had it towed home guy came with his scanner and after the truck would start idle for about 30 seconds would misfire and shake then die and start back up after cranking (crank time was the same always about 10 seconds).
his scanner showed 1 3 5 balance codes would go to -28 is what he said I'm pretty sure. And the whole underneath my truck is covered in oil bad. Yet I crawled everywhere looking for an oil leak but nothing I could find. The injectors were just built and he was suppose to have rebuilt my powermax also.
The only problem I had before was stiction. So I decided to have it tore down and bulletproofed, injectors built, and the sct. Any ideas to what is causing this. It's been towed back to the shop but I still would like to know what's going on.
