I feel the premium transtar pump is better because it has the sonnax pr valve upgrade and tcc plunger upgrade both are common points of problems in these pumps. Not to say if u got one from ford it wouldn't be good I just prefer to take care of a known problem for good..
The drawback is this negates the ability to run the Transgo pressure relief.
Concerning all the converter issues on here. I would suggest putting in a new converter clutch solenoid. Probably won't fix a existing slippage issue but could stop a new converter from doing it if caught soon enough. We had a converter failure, put in a new converter and could still see minor slippage, 200 rpm. Replaced the solenoid and fixed it. Keep in mind this was within 10 miles of installing the new converter, so it was never hurt.
It may not be a huge concern for some. Sounds like a few have had problems with the pressure relief bleeding off too much pressure
I will agree that you cant use the transgo relief but the reason transgo puts that there is do to unblance oil on pr valve caused by wear.
The sonnax valve can wear also, just a thought. I use factory ford pumps typically.
