New injector now no start, need advice
Addicted4
Friend brought me his truck, 2008 cclb 4x4 auto lariat 6.4 113k miles.
Said number 8 injector was stuck open and if I would change it, I did and now it won't start, cycled key, bled the fuel system, scanned it to find that it throws 10 codes every time you crank it for 10-20 secs
P0201-p0208 which are injector circuit malfunction codes?????
I pulled the driver side valve cover, swapped one injector and now I have 8 injector malfunction codes please point me in the right direction
Call or text if you have any ideas or post here thanks
541-979-7445
08BIGRIG
WI
I don't have any answers that you are looking for, but maybe we can get some of the others on here to help out.
4tonGT40
MArietta,Georgia
541-979-7445
I would check for a damaged wiring harness or bleed the fuel system again....other than that Im guessing just like anyone else would be on here.
08BIGRIG
WI
I do remember one thing that happened to me a long time ago like this. Maybe this will work for ya. I belive that I had either some coolant from a hose that I disconnected or some fuel that somehow got into the wire harness on the frame on the drivers side around the area of the degas bottle. If you take these 2 harnesses apart and blast them out with air, and put them back together, I am thinking that you may be in the clear. Try it out and report back. My wheels are turning because I hate to read about things like this happening, but I am thinking that this will help.
